Generate correlation alarm when two specific alarms occur in an element
Solved2.71K views13th August 2024Correlation rule
Min Thant Aung [SLC] [DevOps Member]773 13th August 2024 0 Comments
Hello Dojo,
I am trying to generate a correlation alarm when I have two specific alarms on an element.
For instance, as shown below, I am trying to generate a correlation alarm when there is a Critical alarm severity on Param1 and Param2.
Below is the correlation rule, I am trying to test:
I tried to test with the OR condition and it works fine for me.
But when I changed to AND condition, the correlation alarm is not generated.
Is there something am I missing to apply?
Thank you for the help.
Min Thant Aung [SLC] [DevOps Member] Selected answer as best 13th August 2024
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 13th August 2024 0 Comments
Hi Min,
In addition to what Catarina mentioned, you need to add a rule condition. If you don't do this, no correlation alarm will be generated.
Michaël Pincket [SLC] [DevOps Advocate] Answered question 13th August 2024
