Generate Alarms with an Automation Script
Solved1.30K views1st September 2025alarm alarms Automation script automation scripts licenses
Maxime NOEL [DevOps Advocate]104 3rd April 2025 1 Comment
Hello everyone,
I have created an Automation Script in DataMiner that checks the expiration dates of Nevion Virtuoso MI software licenses.
The script:
  • Identifies licenses that will expire within 50 days.
  • Separates expired licenses from those that are about to expire.
  • Sends an email notification with a list of affected elements.
I would like to know if it's possible to generate DataMiner alarms based on the results of this script. Specifically:
  1. Can DataMiner create alarms dynamically based on calculated values in an Automation Script?
  2. If not, what is the best way to integrate this logic into DataMiner’s alarm system?
Thanks in advance for your insights!
Best regards,
Maxime
Maxime NOEL [DevOps Advocate] Selected answer as best 1st September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Bram Devlaminck [SLC] [DevOps Enabler]922 Posted 3rd April 2025 0 Comments
Hi Maxime,
The answer (from Tobe Deprez) on the following DOJO post is probably what you are looking for:
Show message in active alarms using automation script
Hope this helps.
Kind regards,
Bram Devlaminck [SLC] [DevOps Enabler] Answered question 3rd April 2025
