Force Automation Script to execute from Cube in case of communication lost
Solved1.88K views22nd October 2024#automationscript
Jurica Gajski176 22nd October 2024 0 Comments
Dear,
What is the best way to force automation script to execute from Cube if some of dummy elements lose communication with Dataminer. We have simple script which set one parameter on bunch of elements, but if one of element lose communication with Dataminer, script report error, stop and don’t want to set parameters on another good elements.
Thank you!
Jurica Gajski Selected answer as best 22nd October 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 22nd October 2024 1 Comment
Hi Jurica,
Can you make sure that the option ‘Do not fail when elements are not active or in timeout’ is selected (see General script configuration).
Hope it helps.
Jurica Gajski commented 22nd October 2024
Yes, it helps. Thank you!
Gerwin van der Kamp [DevOps Advocate]4.09K Posted 22nd October 2024 1 Comment
Not sure if this will work but you can try testing for the state of the element. If its in error. If its in error you might want to do some more digging on why it’s in error
Element el = engine.FindElement(“test”);
if (el.RawInfo.State == Skyline.DataMiner.Net.Messages.ElementState.Error)
Jurica Gajski Posted new comment 22nd October 2024
Solved with Miguel advice. Thank you for help!
