Focus Mode for Charts in LCA
Solved655 views2nd June 2025charts LCA low code apps
André Camões [SLC] [DevOps Advocate]575 29th May 2025 0 Comments
I would like to ask if there is a hidden feature, or, if not, whether it is envisioned in the roadmap for implementing a Focus Mode (similar to what exists in Power BI) for charts in LCA
I'm looking for a feature like the one available below:
André Camões [SLC] [DevOps Advocate] Selected answer as best 2nd June 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.61K Posted 30th May 2025 0 Comments
Hi André,
There is no feature similar to this currently available in Low Code Apps. You can create a feature suggestion for us to add something like it.
As a workaround, you could create your own button that opens a panel with the same chart but larger.
