Finding the parent Element in an automation script
Solved1.54K views19th July 2023Automation
Elvio Mendes398 3rd July 2023 0 Comments
Hi Dojo
Given that we know the DMAID and EID on an automation script, how can we find the DMAID/EID of the parent element via the automation script?
Debeuf Klaas [SLC] [DevOps Member]2.05K Posted 4th July 2023 1 Comment
Hi Elvio,
With this snippet you can find fid the parent element.
Element e= engine.FindElement("DVE_E.1");
if (e.RawInfo.IsDynamicElement)
engine.GenerateInformation(${e.RawInfo.DveParentDmaId}/{.RawInfo.DveParentElementId}");
note: This is an internal call and we do not recommend using this, as it is not officially supported and we cannot guarantee that it will still work in the future. As a rule, you should avoid using SLNet calls, as these are subject to change without notice.
Regards,
Floris Cockaerts [SLC] [DevOps Member] commented 4th July 2023
Hi Klaas,
The engine is an object provided to scripts to interact with DataMiner, it may or may not be using SLNet calls under the hood, but it should work regardless. do not believe this is the equivalent to using SLNet calls in your script.
