Filter node-edge dashboard component using a service context
Solved3.62K views26th January 2021Dashboards node-edge
Ive Herreman [SLC] [DevOps Enabler]14.80K 26th January 2021 0 Comments
The node-edge component in the dashboards is very powerful to show me my network topology and the linked KPIs.
Is it possible to filter this topology using a service i.e. only show nodes that are present in a service?
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 26th January 2021
Pieter Van Compernolle [SLC] [DevOps Enabler]4.51K Posted 26th January 2021 1 Comment
Hey Ive,
Like Sebastiaan mentioned you can use the query filter component (currently available in soft launch) to highlight/filter you node-edge.
If you want DataMiner to resolve your service-element relations, we'll probably need an extension being a new data source (Service relations) that you can join with your current query. This way you'll have the service info in your query and you can use it to filter on it.
Ive Herreman [SLC] [DevOps Enabler] Posted new comment 26th January 2021
Ive Herreman [SLC] [DevOps Enabler] commented 26th January 2021
Thank you for the feedback!
I’ve added a feature suggestion on dojo.
https://community.dataminer.services/new-feature-suggestions/add-a-service-relations-data-source-to-the-dataminer-gqi/
