Fastest way to copy an DOM Instance
Solved1.39K views21st March 2023DOM low code app
9
Gerwin van der Kamp [DevOps Advocate]3.71K 21st March 2023 0 Comments
is there an way to copy an DOM instance from an Low code app? We’re building an task app and want to easie clone an task and change maybe only the name and a few other parameters. Basically an save as new or copy instance option.
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 21st March 2023
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 21st March 2023 2 Comments
Hi Gerwin,
Below example will get you started
var instances = domHelper.DomInstances.Read(DomInstanceExposers.Id.Equal(IdOfInstanceToCopy));
domHelper.StitchDomInstances(instances);
var instance = instances.First();
instance.ID = new DomInstanceId(Guid.NewGuid());
domHelper.DomInstances.Create(instance);
Gerwin van der Kamp [DevOps Advocate] Posted new comment 21st March 2023
Jens Vandewalle [SLC] [DevOps Advocate] commented 21st March 2023
Hi Gerwin, I’ve adapted above example. There was a small issue where I used class DomDefinitionId instead of DomInstanceId for assigning a new ID to the instance.
Gerwin van der Kamp [DevOps Advocate] commented 21st March 2023
I just figured that out 🙂 thanks!
