Failover without virtual IP
Solved2.59K views11th July 2023Failover
Bernard Pichot [SLC] [DevOps Advocate]1.44K 23rd September 2021 0 Comments
Hi There,
It's now possible to setup failover with a hostname instead of virtual IP. Does this mean that the two Dataminer agents in failover configuration can be in different IP sub networks ?
Bernard Pichot [SLC] [DevOps Advocate]1.44K Posted 24th September 2021 0 Comments
Thanks for your answers.
How can we be sure that the DNS server will redirect the traffic to the active DMA and not the failover one ?
What about traps, how the devices can send traps to the DMA without using a virtual address ?
Bernard Pichot [SLC] [DevOps Advocate] Answered question 24th September 2021
