Failover Function and licenses
Solved959 views26th June 2025
Jaroslaw Burtny [DevOps Member]756 12th March 2025 0 Comments
Hi All.
We have 12 DMA agents in ecostem DataMiner.
We would like to implement failover based redundancy.
Do we need any licenses to perform failover functions for these 12 DMA MAIN agents and 12 DMA BACKUP agents ?
Do we need any licenses to use the FAILOVER functions ?
Big Thanks for answer.
Br.
Jarek
Danielle Falcone [SLC] [DevOps Advocate]1.49K Posted 13th March 2025 0 Comments
Hello Jaroslaw,
Implementing failover means adding another DataMiner agent, so you will need a license otherwise DataMiner will not start.
Obtaining a DataMiner license | DataMiner Docs
I believe the best approach will be to send an e mail to dataminer.licensing@skyline.be and your sales contact for accurate information.
kind regards,
