Failed Create Package Automation Script
Solved448 views23rd October 2025Automation script solution
Ömer Eryaman [DevOps Member]719 22nd October 2025 0 Comments
Hello,
I created an automation script with Visual Studio. During the publishing I get this error.
Thanks for help!
2025/10/22 15:54:05.718|ERROR: Unexpected exception during package creation for 'ery_tesst': System.MissingMethodException: Methode nicht gefunden: "System.Threading.Tasks.Task`1<NuGet.Protocol.Core.Types.SourcePackageDependencyInfo> NuGet.Protocol.Core.Types.DependencyInfoResource.ResolvePackage(NuGet.Packaging.Core.PackageIdentity, NuGet.Frameworks.NuGetFramework, NuGet.Protocol.Core.Types.SourceCacheContext, NuGet.Common.ILogger, System.Threading.CancellationToken)".
bei Skyline.DataMiner.CICD.Assemblers.Common.PackageReferenceProcessor.<AddPackagesAndDependenciesAsync>d__26.MoveNext()
bei System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine](TStateMachine& stateMachine)
bei Skyline.DataMiner.CICD.Assemblers.Common.PackageReferenceProcessor.AddPackagesAndDependenciesAsync(PackageIdentity package, SourceCacheContext cacheContext, NuGetFramework framework, ILogger logger, ICollection`1 repositories, ISet`1 allPackages, CancellationToken cancellationToken)
bei Skyline.DataMiner.CICD.Assemblers.Common.PackageReferenceProcessor.<ProcessAsync>d__18.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei Skyline.DataMiner.CICD.Assemblers.Automation.AutomationScriptBuilder.<ProcessPackageReferences>d__26.MoveNext()
bei Skyline.DataMiner.CICD.Assemblers.Automation.AutomationScriptBuilder.<BuildDllImportsAsync>d__25.MoveNext()
bei Skyline.DataMiner.CICD.Assemblers.Automation.AutomationScriptBuilder.<BuildExeActionAsync>d__46.MoveNext()
bei Skyline.DataMiner.CICD.Assemblers.Automation.AutomationScriptBuilder.<BuildExeActionsAsync>d__45.MoveNext()
bei Skyline.DataMiner.CICD.Assemblers.Automation.AutomationScriptBuilder.<BuildAsync>d__23.MoveNext()
bei Skyline.DataMiner.Sdk.SubTasks.AutomationScriptStyle.<BuildScript>d__2.MoveNext()
bei Skyline.DataMiner.Sdk.SubTasks.AutomationScriptStyle.<TryBuildingAutomationScript>d__1.MoveNext()
2025/10/22 15:54:08.828|Automation script publishing is finished!
2025/10/22 15:54:42.283|ERROR: Unexpected exception during package creation for 'ery_tesst': System.MissingMethodException: Methode nicht gefunden: "System.Threading.Tasks.Task`1<NuGet.Protocol.Core.Types.SourcePackageDependencyInfo> NuGet.Protocol.Core.Types.DependencyInfoResource.ResolvePackage(NuGet.Packaging.Core.PackageIdentity, NuGet.Frameworks.NuGetFramework, NuGet.Protocol.Core.Types.SourceCacheContext, NuGet.Common.ILogger, System.Threading.CancellationToken)".
2025/10/22 15:56:00.409|Automation script publishing is finished!
Ömer Eryaman [DevOps Member] Selected answer as best 23rd October 2025
Pedro Debevere [SLC] [DevOps Enabler]2.92K Posted 22nd October 2025 4 Comments
Hi Ömer,
A new version of DIS (3.1.13) has been released which should fix this issue. Can you update to this version and verify whether the issue no longer occurs?
Erko Libe [DevOps Enabler] Posted new comment 23rd October 2025
Ömer Eryaman [DevOps Member] commented 23rd October 2025
I updated DIS, and it works now. It was just confusing because in some other projects, the same old version worked fine.
Erko Libe [DevOps Enabler] commented 23rd October 2025
While this System.MissingMethodException is gone in 3.1.13, seems that publishing any project that references another project (ie. .csproj has <ProjectReference Include="..Project1Project1.csproj" />) is now broken.
Error dialog is the same and DIS output just shows:
Build failed of 'C:UserslibeerksourcereposProject5Project5Project5.csproj'
Pedro Debevere [SLC] [DevOps Enabler] commented 23rd October 2025
Hi Erko, other developers also noticed this. We released a new version 3.1.14 which should solve this now. Can you test if that version solves it for you as well?
Thanks, 3.1.14 solved it indeed.
