Extract data from a specific devices on Dataminer
Solved2.25K views19th July 2023
Javier Gordon30 22nd March 2021 0 Comments
Good afternoon team,
They could tell us if there is a way to extract data / tables from specific devices that are kept in the local dataminer database, either by means of a script or something similar.
Our dataminer version is 10.0.0.0-9517-CU6.
Regards
Roger Bijos [SLC] [DevOps Member]455 Posted 26th March 2021 0 Comments
Edgar & Javier - Going into a distributed DB to try and query a consolidated list of elements and or parameters may poses its challenges.
Have you considered using our WebServices (DataMiner Web Services API reference guide) or generating such reports directly in our Dashboards (DataMiner Dashboards - DataMiner Dojo)module? I would strongly advise considering this route.
A similar use case is the combination of "Profiles" as Mediation layer, in combination with Dashboards.
Let's say you have different network devices such as Alcatel & Cisco Switches and you want to display information from both vendors in the same dashboard.
Roger Bijos [SLC] [DevOps Member] Answered question 26th March 2021
