Extract data from a specific devices on Dataminer
Solved2.19K views19th July 2023
Javier Gordon30 22nd March 2021 0 Comments
Good afternoon team,
They could tell us if there is a way to extract data / tables from specific devices that are kept in the local dataminer database, either by means of a script or something similar.
Our dataminer version is 10.0.0.0-9517-CU6.
Regards
Leander Druwel [SLC] [DevOps Member]2.04K Posted 23rd March 2021 0 Comments
It could be important to understand the reason why you want to retrieve information from the database tables.
DataMiner offers many different interfaces to retrieve stored data, and our recommendations will always be to use these interfaces if any data needs to be consulted through any third-party application.
More information on:
https://help.dataminer.services/dataminer/#t=DataMinerUserGuide%2Fpart_3%2FDataminerSystems%2FDataMiner_interfaces.htm
