Extend booking from post-roll and set it to ongoing.
Solved1.36K views10th September 2024lso service orchestration SRM
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K 9th September 2024 0 Comments
I have a requirement where when a booking enters post-roll, under certain circumstances, the booking needs to be extended for 1 hour and set back to ongoing.
I tried using the following method to transition the state back to ongoing (state = “START”):
public void ApplyServiceState (Engine engine, ServiceReservationInstance reservation, string state);
However, the booking gets stuck in the ongoing state after that and LSO isn’t triggered afterwards. Only way to fix that is to manually delete the reservation through client test.
Service states configuration:
Any help is appreciated.
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 10th September 2024
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 10th September 2024 0 Comments
Hi Benjamin,
After the booking is in Post-Roll you can’t go back to ‘Service Active’ as the event already happened.
Though you should be able to apply custom service states like you have in your question, and at the end of the booking the LSO script should run normally.
