Export the routers inputs outputs names in Dataminer from VSM System
Solved1.68K views6th July 2023
6
Rahat Mehmood [DevOps Advocate]86 6th April 2023 0 Comments
Dataminer is showing only ports numbers , can we export the names of inputs and outputs from VSM System
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 7th April 2023 1 Comment
Our "LSB VSM" driver already supports both port numbers and input/output label names. I used it already in some projects.
In the past, I received similar question from another user and in the end they did a change inside the VSM software and then the labels appeared in DataMiner. I personally never used the VSM software directly, but I seem to remember they had to 'add inputs/outputs to virtual matrices' inside VSM. I'll check if I can bring you in contact with that user and let him reply on this post if possible (unless someone else already knows the answer before that ofcourse 🙂 )
Rahat Mehmood [DevOps Advocate] Posted new comment 24th April 2023
Rahat Mehmood [DevOps Advocate] commented 24th April 2023
thanks jochen for this information.
