Executing script on page load AND setting a dynamic variable based on script output
Solved1.93K views28th May 2024Visual Overview
Robin Becker [DevOps Member]1.42K 29th April 2024 0 Comments
I want to execute a script on page load and set a card variable based on the output of that script but not the exact script output.
In practice I want to do something like in the page-level Execute shape data field:
[sep:|@]Script:scriptname@Dummies:dummy=1/2@Parameters:MAC=[thisMAC]@Options:NoConfirmation,CloseWhenFinished@SetTrigger=ValueChanged-[sep:|@]SET@CardVariable@newVar@[Param:1/1,101,[CardVar:scriptOutput]|*]@SetTrigger=ValueChanged
It works when I only have the script but not when I have both.
Robin Becker [DevOps Member] Selected answer as best 28th May 2024
Klaas Dewitte [SLC] [DevOps Advocate]952 Posted 30th April 2024 5 Comments
There seems to be an issue with how automation scripts are handled in an execute shape data when there are also variable placeholders in that shape data.
The variable placeholder seems to retrigger the data which resolves in the script not being executed, so this will have to be resolved.
As a workaround, it seems that the bug also provides a solution, when not having the ExecuteSetsOnInit as option on the page, the retrigger triggers the script which then triggers the set, setting the variable from the automation script.
This is the shape data I added to the page, this puts the "ASOutput1" from the automation script in the newCardVar variable:
I hope this workaround works for your usecase!
Robin Becker [DevOps Member] commented 2nd May 2024
Hi Klaas,
So at the moment it’s impossible to both execute a script & use the script output as a placeholder in a another SET AND also execute unrelated SETs (for example SETs using variables from the InitVar page shape data field) in the Execute page shape data field?
Klaas Dewitte [SLC] [DevOps Advocate] commented 2nd May 2024
Yes currently trying to do that simultaneously at the moment will result in it not working. We have added this issue to our backlog to resolve this issue
The recommendation at the moment is to not use session variables in the execute pagedata field.
What would be the use case of using both initvar and SETs on page level as they do a very similar thing?
Another possible bug: I can’t seem to set the value of newCardVar in your example to a [Param]-placeholder which is using the ASOutput1?
The execute SETs can contain aggregation placeholders like [SUM] and [RegexReplace] which uses variables from the InitVar data field.
For the [param] comment, I dont really understand what you mean with setting it to [Param]-placeholder
In experimenting, I created this:
Script:Test2|||||NoConfirmation,CloseWhenFinished-SET|CardVariable|newCardVar|[cardvar:ASOutput1]|SetTrigger=ValueChanged-SET|Cardvariable|newCardVar2|[Param:956/1,5]|SetTrigger=ValueChanged
Which now sets both the newCardVar and newCardVar2 variables, I did add ExecuteSetsOnInit again because now the automation script will not retrigger as it has no trigger, although i dont know your exact use case
For the sets, you should be able to set the same variables in execute as you can in initvar, now we do recommend that if these sets get very complex to use automation scripts instead as they are more reliable and more performant than running it through Visio
