Executing script on page load AND setting a dynamic variable based on script output
Solved2.07K views28th May 2024Visual Overview
Robin Becker [DevOps Member]1.42K 29th April 2024 0 Comments
I want to execute a script on page load and set a card variable based on the output of that script but not the exact script output.
In practice I want to do something like in the page-level Execute shape data field:
[sep:|@]Script:scriptname@Dummies:dummy=1/2@Parameters:MAC=[thisMAC]@Options:NoConfirmation,CloseWhenFinished@SetTrigger=ValueChanged-[sep:|@]SET@CardVariable@newVar@[Param:1/1,101,[CardVar:scriptOutput]|*]@SetTrigger=ValueChanged
It works when I only have the script but not when I have both.
Robin Becker [DevOps Member] Selected answer as best 28th May 2024
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 30th April 2024 2 Comments
Hi Robin,
Wouldn't it be possible to set the session variable in the script as well?
Passing Automation script output to session variables
Kind Regards,
Jarno
Jarno Lernou [SLC] [DevOps Enabler] Posted new comment 30th April 2024
Robin Becker [DevOps Member] commented 30th April 2024
Hi Jarno,
I’m already setting an output variable in the script but it’s a generic script and I want to try to keep it that way. I’m also setting other variables in the Execute shape data field (using other variables set in the InitVar shape data field), not shown above, which I need to keep as well.
Jarno Lernou [SLC] [DevOps Enabler] commented 30th April 2024
In theory, it should work as I think the logic is available. However, when I was testing the script did not always execute when I added another SET with the output session variable. The software team might give more info on that. I’ll reach out to them.
