Entered wrong DMA ID while installation
Solved2.19K views7th June 2021
Jeyaram Sumanthiran30 6th June 2021 0 Comments
Hello Team,
I am in the process of installing the DM software in the fresh server. While installing the DM software I have entered the wrong DMA ID. Is there any option to change the DMA ID to proceed with the further installation and licensing? or should I need to remove the software and reinstall?
Jeyaram Sumanthiran Selected answer as best 7th June 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 7th June 2021 0 Comments
Hi Jeyaram,
Since you will need to generate again the request file (request.lic) with the correct DMA ID, I believe the best option is to remove and install again DataMiner.
In DataMiner Help you will find the steps to uninstall DataMiner:
Uninstalling a DataMiner Agent
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 7th June 2021
