Enhanced Impersonation Generic Folder Monitor
Solved1.28K views26th June 2023
Richard Henderson196 30th May 2023 1 Comment
When using the Generic Folder Monitor version 1.0.1.4 seem to be having difficulties with local user accounts.
Trying to access a network share to which I can see in windows file explorer using the same credentials.  In the windows explorer is can see all the files without and issue.  On DM I get this…
Check of the folder failed:
System.ComponentModel.Win32Exception (0x80004005): The user name or password is incorrect
at Skyline.Protocol.ImpersonateTools.Impersonator.SetImpersonationContext(String userName, String domainName, String password, IntPtr& token, IntPtr& tokenDuplicate)
at Skyline.Protocol.ImpersonateTools.Impersonator.ImpersonateValidUser(String userName, String domainName, String password)
at QAction.NetworkShareConnection(SLProtocolExt protocol, Credential credential, Boolean utc)
at QAction.Run(SLProtocolExt protocol)
Richard Henderson Selected answer as best 26th June 2023
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 31st May 2023
The error says the username or password is incorrect. Assuming you entered the correct credentials and configured the element as mentioned in https://catalog.dataminer.services/result/driver/4904, can you open the element log file (element_name.txt) and the file SLErrorsInProtocol.txt from the folder C: –> Skyline DataMiner –> Logging and see if you can spot the full exception there ? Usually this exception might contain the QAction ID which can later be investigated.
Philip Argent [DevOps Advocate]1.07K Posted 26th June 2023 1 Comment
The issue is with the logon type and logon provider used in the SetImpersonationContext method in QAction 1.
The protocol uses LOGON32_LOGON_INTERACTIVE & LOGON32_PROVIDER_DEFAULT, as where this article states that LOGON32_LOGON_NEW_CREDENTIALS & LOGON32_PROVIDER_WINNT50 for network shares, which I’ve been using successfully via an automation scripts for some time.
I’ve also modified the protocol, and have got a successful connection.
Richard Henderson commented 26th June 2023
Brilliant – That works a treat.
