engine.SendSLNetMessage – is there any reference/documentation for this method?
Solved1.56K views19th July 20232457 engine
Mateusz Kalisiak10 22nd March 2021 0 Comments
Hello,
simple question, as it is stated in title:  engine.SendSLNetMessage - is there any reference/documentation for this method? I'm looking for description how this can be used.
Regards,
Mateusz
João Severino [SLC] [DevOps Enabler]14.52K Posted 22nd March 2021 0 Comments
The engine.SendSLNetMessage method is used for internal SLNet calls that we do not recommend using, as such, there isn't documentation available for it.
These calls are not officially supported and we cannot guarantee that they will still work in the future.
As a rule, you should avoid using SLNet calls, as these are subject to change without notice.
We recommend instead to always use the correct UI or automation options provided in DataMiner Automation or through our web API.
