Element not connecting to QASNMPSimulations to create Realistic dynamic simulation
Solved1.96K views13th April 2022Connector device protocol SNMP
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 13th April 2022 0 Comments
I’m trying to get a Realistic dynamic simulation for an SNMP element. I’ve followed the DDL (Realistic dynamic simulations) And created the following xml file to upload to the QASNMPSimulator:
<?xml version=”1.0″ encoding=”utf-8″ ?>
<Simulation>
<ProxyAgents>
<ProxyAgent ip=”172.22.161.71″ MacAddress=”” SNMPVersion=”2″ Name=”” Port=”7001″ AutoBuildVersion=”1.2″ deviceIP=”172.29.26.115″ maxDuration=”0.16666666″/>
</ProxyAgents>
</Simulation>
The simulator gives no issues and has created the needed file structure (C:\QASNMPSimulations\ProxySimulations\Alpha UPS DC AC Combi.txt)
I configured the element to listen to 172.22.161.71/7001
But it gets into time out. There is no data coming in. And the .txt file remains empty.
I checked the streamviewer if the commands are being sent, but this seems fine (except for the fact that they are in timeout).
I’ve already tried:
  • Preforming a walk (no issues)
  • Uploading a simulation of a walk and see if the element could reach the simulator app (no issues)
  • Connecting the element to the device to test if it’s reachable (no issues)
  • Changed the IP address of the proxy agent and the element to 127.0.0.1 (didn’t succeed) or 127.0.0.2 (didn’t succeed)
Does anyone know what I could have missed?
Thanks in advance
Timothy Van Poucke [SLC] [DevOps Advocate] Selected answer as best 13th April 2022
Flavio Meneses [SLC] [DevOps Enabler]1.35K Posted 13th April 2022 1 Comment
Hi Timothy,
Can you confirm whether the ip=”172.22.161.71″ is the configured one in the interface that the server uses to communicate with the device? Also, is the device using the default SNMP port?
Kind regards,
Timothy Van Poucke [SLC] [DevOps Advocate] Posted new comment 13th April 2022
Timothy Van Poucke [SLC] [DevOps Advocate] commented 13th April 2022
Indeed, I used wireshark to find out which interface is used, changed it in the simulation file and reloaded it. The file is now being filled in.
Thanks
