Element log issue in Dataminer
Solved1.66K views28th February 2023cefsharp issue log
7
Benjamin Hodžić [SLC] [DevOps Advocate]1.38K 28th February 2023 0 Comments
I tried to open an element log on a customer's DMA, and this pop-up showed:
My questions are:
  1. What could be the root cause of this?
  2. Why is CefSharp used in the Logs?
  3. What is the fix for this issue?
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 28th February 2023
Bert Buysschaert [SLC] [DevOps Advocate]5.06K Posted 28th February 2023 1 Comment
Hi Benjamin,
This will happen when using a Cube version that was installed with an MSI Launcher (shared) package. These packages are found in the C:\Skyline DataMiner\Webpages\Tools\Installs folder on a DMA.
CefSharp is used as the webbrowser engine to display the log files, being served from the connected DMA on http(s)://dma/Tools/ViewLog.asp
The resolution is to either install the CefSharp webbrowser engine as an MSI package (download - requires elevated permissions) or to use another Cube deployment method that has permission to download and install the CefSharp package for the current user.
See the DataMiner Cube deployment methods documentation for more details.
Benjamin Hodžić [SLC] [DevOps Advocate] commented 28th February 2023
Thank you for the explanation Bert, it’s much more clear now
