Element Icon
Solved2.27K views8th April 2024
Catarina Grilo [SLC] [DevOps Enabler]3.63K 3rd April 2024 0 Comments
What is the meaning of this icon?
And where can I find this in the documents?
Min Thant Aung [SLC] [DevOps Member] Answered question 8th April 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 3rd April 2024 0 Comments
Hi Catarina,
I believe that the icon is for an unavailable element.
You can check more info here: DataMiner Cube sidebar | DataMiner Docs
Catarina Grilo [SLC] [DevOps Enabler] Selected answer as best 3rd April 2024
Christine Kapembe [SLC] [DevOps Advocate]1.02K Posted 3rd April 2024 0 Comments
Circle containing a horizontal line indicates that the DMA hosting the item is currently unavailable. Further details available on DataMiner Cube sidebar | DataMiner Docs
Christine Kapembe [SLC] [DevOps Advocate] Edited answer 3rd April 2024
Min Thant Aung [SLC] [DevOps Member]773 Posted 8th April 2024 0 Comments
For additional information, this can occur if the element information is probably stuck in one of the DMAs cache in the cluster after it is being deleted.
It will be interesting to check if the element folder is still existed on the hosting agent. If the element folder doesn’t exist anymore, it means that the element was deleted during a time when DMA’s were disconnected.
Overall, the element should be gone until the next DMA restart.
If you do not wish to wait for the next DMA restart, you may also clear the element by using the Client Test tool with
CTT > Diagnostics > Caches & Subscriptions > RefreshCached Data.
Please note that above command should be executed on all the DMA’s in the DMS.
