ElasticSearch TLS using self signed certificates
Solved2.77K views14th November 2022Elastic elastic cluster Elasticsearch
Philip Argent [DevOps Advocate]1.13K 29th July 2022 0 Comments
I’ve tried connecting DataMiner to an ES cluster that’s using self signed certs, but get the following error in the SLSearch.txt log “The remote certificate is invalid according to the validation procedure.”
Is there a way of allowing this, or do we need to use issued certs?
Gellynck Jens [SLC] Answered question 8th August 2022
Gellynck Jens [SLC]2.72K Posted 8th August 2022 2 Comments
Hi Philip,
Self-signed certificates are supported (but note that issued certificates add more security).
Make sure the IP of the elastic nodes is added in the Subject Alternative Names of the certificate. You’ll have to export the public key of the certificate and trust it (add it to trusted root certification authorities) on the Windows Server hosting DataMiner.
Gellynck Jens [SLC] Posted new comment 8th August 2022
Philip Argent commented 8th August 2022
Thanks Jens,
Adding the cert to the trusted root cert authority was what I was missing.
Does it need to be the IP, can a DNS record be used instead? and if so a wildcard cert?
Gellynck Jens [SLC] commented 8th August 2022
A DNS record can also be used, wildcard certificates should also be supported.
Thomas Deweer [SLC]286 Posted 1st August 2022 0 Comments
Hello,
You can find a guide on how to enable TLS here: Securing the Elasticsearch database | DataMiner Docs
Any shot you missed a step? Perhaps you did not import the certificate on the DataMiner Machine?
Thomas Deweer [SLC] Answered question 1st August 2022
