Dummy element
Solved2.66K views5th May 2022elements Rack View
Thomaz Malmberg [DevOps Member]523 5th May 2022 0 Comments
Is there any way that I can create an "dummy" element that should be visible in my rack view? I have racks with elements that we don´t have included in DM, but we will see them in the rack view.
// Thomaz
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 5th May 2022
Jeroen Geldhof [SLC] [DevOps Enabler]5.52K Posted 5th May 2022 0 Comments
In general you shouldn't generate dummy elements, because these will count for your license count.
I assume you use the Rack Layout Manager.  There it's possible to define 'Other Devices' in the Other Devices Table.  These then don't generate elements but still show a graphical entry in the rack drawing.
