Draw.io as a Visio replacement
Solved3.88K views20th February 2025draw.io Microsoft Visio
Curtis Baiden [DevOps Advocate]596 19th February 2025 0 Comments
Can Draw.io Act as a Complete Replacement for Microsoft Visio When Working with DataMiner Visio Templates?
Curtis Baiden [DevOps Advocate] Selected answer as best 20th February 2025
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 20th February 2025 0 Comments
Draw.io and the other Visio alternatives I've come across do not have support for custom shape data, which is essential to link DataMiner objects to shapes in the drawing. For simple drawings that do not require any link to DataMiner objects, it is possible to export as .vsdx from draw.io and use it in DataMiner, but then you are missing out on most of the functionality visual overview has to offer.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 20th February 2025
