Draw.io as a Visio replacement
Solved3.85K views20th February 2025draw.io Microsoft Visio
Curtis Baiden [DevOps Advocate]596 19th February 2025 0 Comments
Can Draw.io Act as a Complete Replacement for Microsoft Visio When Working with DataMiner Visio Templates?
Curtis Baiden [DevOps Advocate] Selected answer as best 20th February 2025
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 19th February 2025 0 Comments
Currently there are no plans to support draw.io natively through DataMiner Visual Overview. Likely your best bet is to find an optimal way to convert draw.io documents to Microsoft Visio ones and then use those. But of course that all depends on your use case as draw.io does not offer shape data, which is essential for linking Visio shapes to their DataMiner object (element, view, service) counterparts.
