DOM Module Settings – Failure on creating a new module setting
Solved2.13K views7th March 2023DOM
Robin Meurisse [SLC] [DevOps Advocate]1.51K 7th March 2023 0 Comments
We are trying to get DOM up and running on a staging system running 10.3.2 (no previous Module Settings, DOM definitions, ... exist). However creating a new module does not seem to work.
The code we are running is the same as in the Invoice example from the docs.
var moduleSettingsHelper = new ModuleSettingsHelper(engine.SendSLNetMessages);
var moduleSettings = new ModuleSettings("abr_ott_profile_app");
moduleSettingsHelper.ModuleSettings.Create(moduleSettings);
The SLSearch Log is indicating a read-only exception:
2023/03/07 10:48:43.282|SLDBConnection|ElasticCustomData||Index<ModuleSettings>|INF|0|12|Invalid response from Client.IndexMany call: Invalid NEST response built from a successful low level call on POST: /dms-active-cmodulesettings/_bulk
# Invalid Bulk items:
operation[0]: index returned 403 _index: dms-cmodulesettings-2023.01.12.08-000001 _type: object _id: abr_ott_profile_app _version: 0 error: Type: cluster_block_exception Reason: "blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];"
Is there a pre-requisite or component that we could be missing on this system to be able to make use of DOM? The softlaunch option for type DomManager has been enabled.
Thanks in advance.
Robin Meurisse [SLC] [DevOps Advocate] Selected answer as best 7th March 2023
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 7th March 2023 1 Comment
Hi Robin,
Just a long shot, but maybe at some point in time your elastic cluster went into read-only mode because it hit the watermark low threshold.
Can you please try to enable read-write again by sending the following HTTP query to your cluster (using e.g. postman or kibana)
PUT _settings
{​​​​​ "index": {​​​​​ "blocks": {​​​​​ "read_only_allow_delete": "false" }​​​​​ }​​​​​ }​​​​​
Robin Meurisse [SLC] [DevOps Advocate] Posted new comment 7th March 2023
Robin Meurisse [SLC] [DevOps Advocate] commented 7th March 2023
Thanks Ive, that did the trick!
It must indeed have hit that threshold at some point.
