Does trending work correctly for discreet string parameters?
Solved2.37K views19th July 2023trending
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 11th March 2021 0 Comments
It has always been best-practice to not trend regular string parameters, for obvious reasons.
I wonder though if the same applies to string parameters of type 'discreet'?
What are the specific features - could be client and/or server side - which are not supported for such parameters?
Should we always aim to convert these to numerical discreets?
What's Skyline's advise on this?
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 11th March 2021 0 Comments
Trending on string parameters (including string discreets) are not supported in the web and mobile applications (Reports & Dashboards, Monitoring, Custom apps, WebAPIs). So if you want to view the trending in these apps it will be better to use numerical discreets.
