Does method GetParameters perform less well than GetParameter when requesting 1 single parameter
Solved2.36K views24th June 2021QAction scripting
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 24th June 2021 0 Comments
Does requesting one single parameter using the method GetParameters perform less well than using the method GetParameter?
Maxim Bouckaert [SLC] [DevOps Member] Answered question 24th June 2021
Maxim Bouckaert [SLC] [DevOps Member]169 Posted 24th June 2021 0 Comments
Hey Jens,
Just to give some more feedback/measurements to this. I did some quick tests to find out the difference between these calls. I tested the following two calls, each 1.000.000 times:
protocol.GetParameter(101)
protocol.GetParameters(new uint[]{101})
The first loop took about 21 seconds, the second one took 32 seconds.
It seems to be 30% faster to use the first call. Do note that this difference is negligible when doing a moderate amount of calls.
