DMS communication problem between agents
1.45K views7th August 2026DMA DMS SLNet
Isabel Arce [DevOps Member]214 10th June 2026 0 Comments
We recently updated a cluster of 3 dataminer agents to version 10.6 CU3. Accessing the cluster from DMA1 and DMA2 shows all 3 agents connected, but accessing it from DMA3 shows DMA2 and DMA1 in an "Unknown" state. We've verified connectivity between the 3 agents via ports 443, 8004, and 80. Would it be helpful to send a "SetConnectionUriMessage" message to resolve this issue? What fields would be required to send this message? Is there another way to resolve this problem? Thank you in advance.
Juan Nicola [SLC] [DevOps Advocate] Answered question 7th August 2026
Juan Nicola [SLC] [DevOps Advocate]162 Posted 7th August 2026 0 Comments
Hi all,
Just to provide a final update: the issue was resolved by adding both connections via “Edit Connection Uris” in the Advanced menu of the SLNetClientTest tool.
Thank you again, Isabel, for the feedback!
