DMA starting up at 99% after an hour
Solved2.19K views1st December 2023cloud pack DataMiner Agent
Vincenzo Converso [DevOps Member]92 29th November 2023 0 Comments
I am new in the use of Dataminer and i've set up a localhost agent to try some stuff but after I have installed the Dataminer Cloud Pack when i start my agent the process remain at 99% without progess.
ADAMA TOURE Answered question 1st December 2023
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 30th November 2023 0 Comments
Installing the Cloud Pack will/should not affect your DataMiner startup or DataMiner installation as they are separate services running next to each other. To eliminate the cloud pack being the cause of this you can easily uninstall it again via control panel.
Jordy Ampe [SLC] [DevOps Advocate] Answered question 30th November 2023
