DMA failover monitoring
Solved1.72K views18th January 2023DMA Failover
Dave Keller [DevOps Enabler]1.92K 26th July 2022 0 Comments
Is there a good way to monitor DMA failover history?  We have several DMAs in our DMS and are trying to get to the bottom of a few issues, but there doesn't seem to be an obvious high level way of monitoring when DMAs failed over and what was the cause.
Is there a Protocol that can monitor DMAs and has access to the information that is in System Center?
Dave Keller [DevOps Enabler] Selected answer as best 18th January 2023
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K Posted 27th July 2022 0 Comments
You can give this Generic Failover Status connector a trial. With this you can monitor/trend the failover state of a pair of agents. It also shows details similar to what you willl find when you view the current failover status of a DMA.
