DMA Cube connection
Solved1.05K views28th March 2025Cube DMA getting started localhost
Ashok Mahala [DevOps Member]249 23rd September 2024 0 Comments
After restarting my system I am not able to connect with my localhost Agent. It is Saying dataminer agent is getting started and stuck on 99%. I have attached the screenshot also. I was able to connect before restart now to solve this issue again i have to uninstall and reinstall Dataminer agent then only it will work.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Pieter Van Compernolle [SLC] [DevOps Enabler]3.87K Posted 23rd September 2024 1 Comment
When your DataMiner start-up is stuck at 99%, then most-likely it will not reach 100%. The percentages we show are based on recent DataMiner start-up times and if you reach 99%, it’s taking a lot lot longer that usual.
If you want to investigate yourself, checkout the c:\Skyline DataMiner\Logging folder. The files with the most recent ‘Date modified’ might hint you in the correct direction.
If your agent has a valid support contract, you can get in touch with our techsupport of course as well.
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
More information about DataMiner startup troubleshooting is now also available here: https://docs.dataminer.services/user-guide/Troubleshooting/Troubleshooting_Flowcharts/Troubleshooting_Startup_Issues.html
