DM 10.x Limiting Alarm by Max Number
Solved896 views28th August 2025
Merlin Nguehou12 19th November 2024 2 Comments
Hello all,
I noticed starting with DM 1.1 the maximum alarms and the fallback minimum is set to "0" by default and when you initiate the change to the known value of 300,000 and 100,000 alarm after applying the new changes it immediately reverts to "0"
Any idea how this can be corrected and what does "0" mean in this case?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 25th April 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2025
José Silva [SLC] [DevOps Enabler]2.05K Posted 12th December 2024 0 Comments
Hi Merlin,
I only found this on documentation: Configuring the SQL database settings | DataMiner Docs, which might be relevant.
It’s possible that the value you’re trying to set is not allowed by the system (?). The behavior of reverting to "0" could indicate a validation failure or a restriction on the acceptable range of values, imo.
Have you tried using the up and down arrows after entering the desired value? Sometimes, interacting with these controls can help the system recognize and validate the input. For instance, after entering "300,000," try pressing the up arrow once and then the down arrow to see if it adjusts to the maximum allowed value automatically.
Let me know how it goes!
Kind regards,
