Display trend data in a dashboard for a parameter with indices
Solved3.14K views13th April 2022Dashboards trend
Bethany Sheppard20 12th April 2022 0 Comments
I have a parameter with 3 indices, showing 3 different values. In the dashboards web app, how can I select an index to display a trend graph?
Bethany Sheppard Selected answer as best 13th April 2022
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 12th April 2022 1 Comment
Hi Bethany,
You can easily achieve this in 3 steps:
  • Add a drop down feed and give it some indices as data. You should see the display value of the indices in the drop down.
  • Add a line chart and give it a trended parameter as data (the indices are of course part of the same table as this parameter). This will not show any data just yet since it doesn't know for which index it needs to show data.
  • Feed the indices as a filter on the line chart.
The result should be something like this:
Bethany Sheppard Posted new comment 13th April 2022
Bethany Sheppard commented 13th April 2022
Thank you
