Display number of alarms in dashboards for a specific View or saved Alarm Filter
Solved1.94K views18th April 2024alarms Dashboard low code app views
Justien Decuypere [SLC] [DevOps Member]322 16th April 2024 0 Comments
Hi Dojo
Could someone assist me in displaying the count of alarms, grouped by alarm types, for a particular view or saved alarm filter on a dashboard?
Now, this has been tested using a grid component, but if there's another method available, that's also ok.
Image serving as an illustration of the desired appearance
We can filter alarms by severity and display each view in the grid, showing the overall alarm color based on the selected alarm state in the Get views function. However, we're currently unable to integrate this with the count of alarms per alarm type.
Thank you for the assistance!
Justien Decuypere [SLC] [DevOps Member] Selected answer as best 18th April 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 18th April 2024 1 Comment
Hi Justien,
The grid component can be used to display the different views with the amount of alarms per severity level.
To gather that information you could opt for an ad hoc GQI datasource which calculates the amount of alarms per severity level. Following data source could be a good starting point for what you want to achieve: https://github.com/SkylineCommunications/SLC-GQIDS-HighestSeverityAlarmCountPerView
Best regards, Ward
Justien Decuypere [SLC] [DevOps Member] commented 18th April 2024
Hi Ward
That certainly sets us on the right path. Much appreciated for your assistance!
Kind regards
Justien
