Display Min, Max and Avg or a period of time
Solved1.60K views4th May 2023
Kristopher Brookshire [DevOps Member]220 3rd May 2023 0 Comments
We are trying to get a table like the one below that will provide the Min/Max/Avg for each test point over the course of a month.
Even though this says it is for the previous month it is just showing the latest values.
Is there a way for us to get Dataminer to provide what we are looking for in a report format?
Kristopher Brookshire [DevOps Member] Selected answer as best 4th May 2023
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 3rd May 2023 0 Comments
Hi Kristopher,
With the pivot table (Pivot table | DataMiner Docs) in dashboards, you can easily achieve this behavior. Below you see an example where the Avg, Min and Max are shown for the Total Processor Load and Physical Memory of the server. Note that the time range can be configured by the user directly from the GUI using the Time Range component (Time range feed | DataMiner Docs) and passing it as feed to the Pivot table.
Rene De Posada [SLC] [DevOps Advocate] Answered question 3rd May 2023
