Display current preset name in use by Spectrum element
Solved982 views24th April 2025spectrum analyzer
Alain Faivre [DevOps Member]276 21st April 2025 0 Comments
Hello Community,
I have a Spectrum component in a visio and I would like to add a shape displaying the current preset name in use by the spectrum analyzer.
What is the property/Parameter to be used for that ?
Thanks,
Alain Faivre [DevOps Member] Selected answer as best 24th April 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K Posted 21st April 2025 1 Comment
Hi Alain,
Does this page Embedding a Spectrum Analysis component | DataMiner Docs help you ?
Alain Faivre [DevOps Member] Posted new comment 21st April 2025
Alain Faivre [DevOps Member] commented 21st April 2025
Hi Arunkrishna,
In fact, I already have the Spectrum component embedded into my visio.
There are several traces which alternate and I would like to display in a separate shape the preset which is currently used by the spectrum (i.e. corresponding to the trace displayed). Thank you
