DIS Suggested Lists Not Appearing in Visual Studio 2022
Solved1.32K views9th August 2024DataMiner Integration Studio DIS installation Visual Studio
Johannes Boshoff [DevOps Member]384 7th August 2024 0 Comments
Good morning.
I am new to DIS. I have been working through the online training. In one of the sections "Data Ingest and Control Plane Development: Concepts" it is shown on the screen that DIS suggests options for the type field after the snippet is added for example
<Measurement>
<Type>(dropdown with options)</Type>
</Measurement>
On my setup however I do not receive any options, so I'm not sure if I perhaps missed a configuration step somewhere? I could also not do the same as what was showed in the video where I click on File->New->File as I do not have the option Dataminer under general, I could do this by selecting a new project and then selecting DataMiner Connector Solution which up until now gave me the same result as seen in the video so I did not think much of it.
Here is an example of what is shown in the video
And then what I see
My options for "new" files
I also read in previous questions allot of times it was due to the NuGet packages not configured correctly, I had a look at mine and they do look correct from my untrained viewpoint, picture for reference.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 9th August 2024
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 9th August 2024 0 Comments
Hi Johannes,
These suggestions are auto generated by Visual Studio based on the xml schema definition. If you should continue to have issues with the suggestions you can check these things:
  • Verify that the connector you are working on has the correct "xmlns" attribute in the protocol tag: <Protocol xmlns="http://www.skyline.be/protocol">
  • Verify that the protocol.xsd file is present in this path: C:\Program Files\Microsoft Visual Studio\2022\Professional\xml\Schemas\. If all went well during the DIS installation, it should be there already. Note this path can be slightly different depending on your Visual Studio version and installation options.
Michiel Vanthuyne [SLC] [DevOps Advocate] Edited answer 9th August 2024
