DIS Macros not updated
Solved1.57K views17th May 2023DataMiner Integration Studio DIS DIS Macros
Simon Vandamme [SLC] [DevOps Advocate]1.01K 8th May 2023 0 Comments
Hi all,
After updating my DIS to a new version, I noticed that my DIS Macros are not being updated accordingly.
What could cause this?
Simon Vandamme [SLC] [DevOps Advocate] Selected answer as best 17th May 2023
Pedro Debevere [SLC] [DevOps Enabler]2.95K Posted 8th May 2023 1 Comment
Hi Simon,
you’ll probably need to run VS as administrator. When opening the DIS macro tool window, it tries to copy the macros to a folder but if you don’t have sufficient rights it will throw an exception (which can be seen in the DIS output window).
Simon Vandamme [SLC] [DevOps Advocate] commented 8th May 2023
Thanks Pedro, I can confirm running VS as administrator solves this issue.
