DIS error no appropiate connection could be created for ip
Solved938 views3rd April 2025
Juan Falcon [DevOps Member]338 27th March 2025 3 Comments
Hello
im having probles with the DIS connexion, whn i test the coneccion i have the message "no appropiate connection could be created for ip" ising the last version, from the cube i  have no issue for connetion, any idea of why is happening this?
Thanks
Juan Falcon [DevOps Member] Selected answer as best 3rd April 2025
Davor Joleski [DevOps Enabler] commented 27th March 2025
HI Juan are you loged in in VIsual studio with the same email or something
Juan Falcon [DevOps Member] commented 28th March 2025
yes, i know that it happens to other persons with yhis DMA
Davor Joleski [DevOps Enabler] commented 1st April 2025
i would suggest to try upgrade Visual studio if it has so proper packages .Try first delete DIS then upgrade VIS then donwload DIS i hope will work 🙂
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 28th March 2025 7 Comments
Hi Juan
Could you check which DIS version you are using (is visible in the About of Visual Studio and in the settings of DIS as well). Currently we are on v3.1.7 where that issue is fixed.
Hello Michiel, im using the version 3.1.7, the DMA has 10.3.0.0-15150-CU21. any idea of troubleshooting? same problem with other persons on this DMA.
this are the error:
28 06:02:12.035|> Exception: (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: No appropriate connection could be created for …………… —> System.AggregateException: Se han producido uno o varios errores. —> System.Reflection.TargetInvocationException: Se produjo una excepci¢n en el destino de la invocaci¢n. —> Skyline.DataMiner.Net.Exceptions.DataMinerOfflineException: APIGateway is unavailable.
2025/03/28 06:02:12.035|> en Skyline.DataMiner.Net.GRPCConnection.GRPCConnection.PerformInitChecks()
2025/03/28 06:02:12.035|> en Skyline.DataMiner.Net.GRPCConnection.GRPCConnection.Init(Uri endPointUrl, Boolean makeConnection)
2025/03/28 06:02:12.035|> en Skyline.DataMiner.Net.GRPCConnection.GRPCConnection..ctor(Int32 portOverride, Uri endPointUrl, ConnectionAttributes attributes, String subDir)
2025/03/28 06:02:12.035|> en Skyline.DataMiner.Net.GRPCConnection.GRPCConnection..ctor(Int32 portOverride, String endPointUrl, ConnectionAttributes attributes)
2025/03/28 06:02:12.036|> — Fin del seguimiento de la pila de la excepci¢n interna —
2025/03/28 06:02:12.036|> en System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
2025/03/28 06:02:12.036|> en System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
2025/03/28 06:02:12.036|> en Skyline.DataMiner.Net.ConnectionSettings.CreateConnection(String hostName, ConnectionAttributes extraAttribs, Type[] supportedTypes)
2025/03/28 06:02:12.036|> en Skyline.DataMiner.Net.ConnectionSettings.GetConnection(String hostName, ConnectionAttributes extraAttribs, Type[] supportedTypes)
2025/03/28 06:02:12.036|> en SLDisDMAComm.SLDisDmaCommService.ConnectInternal(String hostname, String username, String password, Boolean disableProtoBufSerialization) en D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:l¡nea 1276
2025/03/28 06:02:12.036|> en SLDisDMAComm.SLDisDmaCommService.ConnectInternal(String hostname, String username, String password) en D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:l¡nea 1254
2025/03/28 06:02:12.036|> en SLDisDMAComm.SLDisDmaCommService.TestConnection(String hostname, String username, String password) en D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:l¡nea 280
2025/03/28 06:02:12.036|> Finished executing TestConnection
Michiel Oda [SLC] [DevOps Advocate] commented 28th March 2025
Hi Juan
Looking in the stacktrace I see the following: Skyline.DataMiner.Net.Exceptions.DataMinerOfflineException: APIGateway is unavailable.
Could you check if APIGateway is properly up and running?
how do i check? the Cube, dashboards and Low code app are working
This is something you can see in the Task Manager on the system itself. In the services you should see 'DataMiner APIGateway'
is not on the task manager
Show 2 more comments
