Differentiating DataMiner Systems on Cube
752 views7th July 2026Cube
Bautista Solanet [SLC] [DevOps Advocate]1.36K 6th July 2026 0 Comments
Hey Dojo,
I want to know how the community helps differentiate their systems at a glance, especially between Production and Lab systems. The idea here is that a user always knows if they're on a Production system or not. I have it so my Production systems use the Light theme while my Lab systems are on Dark mode, but this is an individual solution, I'm interested in solutions that can be implemented for all users on a system.
Thank you,
Bauti
Matthias Declerck [SLC] [DevOps Advocate] Answered question 7th July 2026
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 7th July 2026 0 Comments
Hi Bautiste,
I would show the cluster/system name in the Cube header. Hope this helps.
Example:
Regards,
Matthias
Matthias Declerck [SLC] [DevOps Advocate] Edited answer 7th July 2026
