Difference between visible alarms in workspace and in alarm console
Solved1.94K views24th November 2022alarms suppression workspace
ryan yahia900 1st December 2021 0 Comments
We have a workspace which shows alarms which are showing suppressed alarms as type “Normal”. However we don’t want these alarms to be shown in the workspace. Are there any settings that can be applied that will ignore these suppressed alarms too?
Thanks,
Ryan
ryan yahia Selected answer as best 24th November 2022
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 2nd December 2021 2 Comments
Hi Ryan,
In a card you can go to the hamburger menu and adapt the settings of your alarmconsole shown in the card. Maybe you can compare these settings with the ones of your “main” alarmconsole and see what the difference is. In case this did not resolve your problem, is it possible the add a screenshot to illustrate your problem?
ryan yahia commented 7th January 2022
Hi Michaël,
Thank you for your answer. I have found one difference between the alarm console and the custom workspace alarm console, is that one of the settings “Default alarm list” is not selected on the workspace console.
What effect does selected default alarm list have on the alarms that appear. I will set up my environment and test if this solves the issue.
Thanks,
Ryan
Michaël Pincket [SLC] [DevOps Advocate] commented 7th January 2022
Hi Ryan,
The “Default alarm list” setting does not influence the alarms. It just indicates the tabpage that should be selected when you connect.
