Difference between SeverityBubbleUp and Alarm Bubble up through relations
Solved1.33K views8th May 2024alarm bubble-up SeverityBubbleUp
Chian Hao Aw [SLC] [DevOps Member]650 8th May 2024 0 Comments
What is the difference between a SeverityBubbleUp element:
<SeverityBubbleUp>
<Path>5000;4000;3000</Path>
<Path>2000;3000</Path>
</SeverityBubbleUp>
and the "includeInAlarms" option in Relations when linking tables? (<Relation path="100;200;500" options="includeInAlarms:topology1"/>)
What are their respective applications, and which method is more suitable if I want to to enable alarm bubble-up on a TreeControl?
Chian Hao Aw [SLC] [DevOps Member] Selected answer as best 8th May 2024
Laurens Moutton [SLC] [DevOps Enabler]9.91K Posted 8th May 2024 0 Comments
SeverityBubbleUp is used in an EPM environment to determine the path of the alarm severity bubble in the topology.
includeInAlarms is intended to be used for the alarm severity bubble in a TreeControl.
Regards,
