Device pages not properly rendered inside cube embedded engine
Solved2.74K views18th July 2023web interface page
Sergio Abreu [SLC] [DevOps Member]221 22nd June 2021 0 Comments
Hi Community,
Some device web pages are not properly rendered when open from cube embedded engine normally link to the “WebInterface” drive page.
Have some device pages missing background color or table columns that are overlapping.
Is this a known issue?
can it be some limitation on compatibility mode or internal Javascript engine.
Inside Protocol.Display is there any tag we can use for better compatibility?
Thanks in advance
Leander Druwel [SLC] [DevOps Member]2.11K Posted 22nd June 2021 0 Comments
Hi Sergio,
Just an idea, but you could try to set IE or Chromium as Web Browser Engine on the Cube > System Center > System settings > Plugins page, and check if that would make any difference.
Optionally, if you want a different browser to be used for a specific protocol, you can also add an exclusion.
More information also on DataMiner Help
Sergio Abreu [SLC] [DevOps Member]221 Posted 3rd September 2021 0 Comments
Above post solved the issue for a Cube, can that take effect to a group of users? i.e. can we have such feature under Settings -> Group Settings ?
It might happen that some users do not have permissions to System Center -> system settings.
Customer running on 9.6 default is still IE.
Sergio Abreu [SLC] [DevOps Member] Answered question 3rd September 2021
