DELT export for Spectrum Analyzer, best practices for exporting or migrating spectrum elements
Solved888 views19th February 2025DELT element migration Export/Import spectrum analyzer
Alexander Gorbunov [SLC] [DevOps Advocate]1.19K 17th February 2025 0 Comments
I haven't found a confirmation in DataMiner Docs, but it seems to be impossible to export, import, or migrate a Spectrum Analyzer element (in my case, the protocol is "SED Decimator 8 port"). In Cube, I don't see an option to export this element to a .dmimport package nor to a .csv file.
Can somebody confirm that this is not supported? And if this is the case, what would be the most efficient way to migrate a Spectrum element from one DMS to another?
Thanks!
Alexander Gorbunov [SLC] [DevOps Advocate] Selected answer as best 19th February 2025
Tom Van Bruaene [SLC] [DevOps Member]913 Posted 17th February 2025 0 Comments
Spectrum Elements can indeed not be exported yet, and I'm afraid the only workaround is to recreate the element on the other DMS and manually copy over the settings/scripts.
(Not this is documented in the migration documentation, but not in the DELT docs: https://docs.dataminer.services/user-guide/Advanced_Functionality/DataMiner_Systems/Migrating_elements_in_a_DataMiner_System.html )
