Delete element from protocol code
Solved1.79K views30th May 2023delete elements protocol
Thibault Heylen [SLC] [DevOps Member]1.51K 30th May 2023 0 Comments
Hi all,
What is the preferred way of deleting an element from  protocol code?
Is this using the NT_DELETE_ELEMENT(5), or is their a direct command for this?
Thank you in advance.
Thibault Heylen [SLC] [DevOps Member] Selected answer as best 30th May 2023
João Severino [SLC] [DevOps Enabler]14.49K Posted 30th May 2023 0 Comments
Hi Thibault,
What I have used in the past is the Delete method from the IDmsElement object of Class Library.
João Severino [SLC] [DevOps Enabler] Answered question 30th May 2023
