Delete DOM instances using filter
Solved1.27K views22nd July 2024DOM
Tom Waterbley [SLC] [DevOps Enabler]10.01K 19th July 2024 0 Comments
Is it somehow possible to delete all DOM instances that match a specific filter directly, without needing to retrieve all matching instances first?
Tom Waterbley [SLC] [DevOps Enabler] Selected answer as best 22nd July 2024
Pieter Carlu [SLC] [DevOps Advocate]260 Posted 22nd July 2024 0 Comments
Hi Tom,
Currently it’s only possible to remove multiple instances by passing the list of instances you want to delete. You can find more information here: https://docs.dataminer.services/user-guide/Advanced_Modules/DOM/DOM_examples/DOM_BulkProcessing_Example.html#remove-multiple-dominstances
