Define Y axis for Trending on vision.
415 views20th October 2025
Henri Martins [DevOps Advocate]741 20th October 2025 0 Comments
HI.
We open on Visio a trending page using:
  • VdxPage : Trend|popup
  • LinkOptions : With=111|Height=222
On the trending shape we use:
  • Component : Trending
  • Parameters : aaa:1000:1
How could we define Y axis?
Thanks.
Toon Casteele [SLC] [DevOps Enabler] Answered question 20th October 2025
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 20th October 2025 2 Comments
It's not possible to set the y axis range through Visio shape data.
The trend graph follows the same logic as the one in data display, which is to use the user setting that's either set to auto scaling or fixed range scaling. To change the range, you can right click in the trend graph and click "Y axis settings...".
Toon Casteele [SLC] [DevOps Enabler] Posted new comment 20th October 2025
Henri Martins [DevOps Advocate] commented 20th October 2025
When we do a rigth clic and define manual values, the trending disapears and on the next try , the values are not changed. ( DMA release 10.5.9.0-16293).
I will contact Techsupport.
Toon Casteele [SLC] [DevOps Enabler] commented 20th October 2025
The y axis range you set manually is indeed not remembered for the next time you open it. For the trend disappearing though, we would indeed need to investigate.
