DateTime format without custom operator in LCA
Solved1.12K views28th April 2025low code app
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 28th April 2025 0 Comments
I found this question + answer related to changing the formatting of a DateTime field.
Is it possible to only show the date (not the time) without a custom operator?
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 28th April 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.33K Posted 28th April 2025 0 Comments
Hi Mieke,
You can only choose a custom format using a custom operator.
